I have a 2006 Mazda 6i sport. I recently got this trouble code which means lean at idle. From research, it appears this is normally associated with a vacuum leak or sometimes a bad purge solenoid valve.
I have inspected my intake and all the hoses, tubes and air filter seemed tightly fit and no leaks or cracks.
The odd thing I did notice while checking this was that during idle, the RPMs were constantly varying, not by enough to show up on the tach, but enough to tell audibly.
Any; guesses what this issue is?
