BW-44-44 Transfer Case special fluid
by -SyN-
06/25/16 02:27 PM
mini inspection camera for androi phone
by bmwjohn
06/25/16 02:15 PM
Cause of noisey serpentine belt
by 007
06/25/16 01:48 PM
Purolator Boss 14610 C and p
by bbhero
06/25/16 01:33 PM
Ear hair - remove, ignore, trim ???
by Mr Nice
06/25/16 01:04 PM
Best Oil for [censored] Intek 19 HP Mower
by beadvised
06/25/16 12:43 PM
by bbhero
06/25/16 12:42 PM
Was the original Mobil 1 a Straight 20?
by Gene K
06/25/16 12:23 PM
Valvoline Maxlife 0w20 Synth blend?
by HKPolice
06/25/16 12:11 PM
Walmart Canada (GTA) Valvoline MaxLife 0w20 $18.88
by HKPolice
06/25/16 11:49 AM
Makita B04510 Palm Sander - Fix?
by user52165
06/25/16 11:41 AM
Red Arrows
by Whitewolf
06/25/16 11:20 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
79 registered (86cutlass307, -SyN-, 360kid, 69GTX, 007, 2015_PSD, 10 invisible), 2027 Guests and 11 Spiders online.
58257 Members
66 Forums
250798 Topics
#2792548 - 11/04/12 07:50 AM Toyota WS vs. Toyota Type 4 fluid
exman123 Offline
Loc: NC
Gang,
I have a 2005 Lexus GX 470 with. 4.7L V8 80k miles. I took it to a Lexus dealer to have the transmission flushed just a preventative measures. No problems with the tranny at all.
The dealer put in Type 4 fluid. When I got home..120 miles away. I noticed the mistake. I called the dealership and they said it needed WS fluid as I knew and told me to bring it back..UGH...Another 120 miles to the dealer.
I put 240 miles on the tranny with the wrong fluid. Did this damage my tranny?
Is Type 4 and WS compatible? They did another flush and put in WS fluid. The tranny seems to shift just fine.
Just wondering the long term affects of driving 240 miles on Type 4 fluid.
Thanks!
2005 Lexus GX 470
2014 Toyota Sienna XLE
2010 Ford Fusion SE
#2792572 - 11/04/12 08:17 AM Re: Toyota WS vs. Toyota Type 4 fluid [Re: exman123]
hypervish Offline
Loc: new jersey
The GX470 has a very stout transmission, I think it will be just fine. Although I'd be tempted to get one more flush just to be on the safe side. And, I assume by flush you mean fluid exchange, correct?
2000 Lexus RX300 AWD 234k miles
QS Ultimate Durability 5W-30
Tranny - Castrol Transmax IMV / T-IV
Transfer Case and Rear LSD - Royal Purple 75w-90
#2792574 - 11/04/12 08:19 AM Re: Toyota WS vs. Toyota Type 4 fluid [Re: exman123]
simple_gifts Offline
Loc: Middlesex County CT
OT:That dealer is clearly not worth the 120 mile drive.
Why does the customer have to specify the correct fluid?
2003 Echo >392K miles; Castrol 5W-50
2006 B2300;108K;ALM
Please conserve paper; it is not like it grows on trees.
#2792588 - 11/04/12 08:32 AM Re: Toyota WS vs. Toyota Type 4 fluid [Re: exman123]
JC1 Offline
Loc: Oshawa, Ontario Canada
Originally Posted By: exman123
Gang,
Thanks!
You should be ok. Next time do it yourself. Then you can save yourself a 240 mile drive.
Regards, JC
#2792784 - 11/04/12 01:39 PM Re: Toyota WS vs. Toyota Type 4 fluid [Re: JC1]
exman123 Offline
Loc: NC
Thanks all. Are these 2 fluids not compatible? If not what may happen if the full fluid exchange didn't get 100% of he T4 out of the tranny?
2005 Lexus GX 470
2010 Ford Fusion SE
#2792888 - 11/04/12 03:35 PM Re: Toyota WS vs. Toyota Type 4 fluid [Re: exman123]
bmwtechguy Offline
Loc: South Carolina
It is doubtful any damage was done at all. The WS is most likely a higher quality fluid, because it probably has more synthetic base oil and longer lasting friction modifiers in the newer spec fluid. It starts out at a lower-viscosity than the T-IV does most likely. I am of the opinion that it did not do anything except give your transmission a really good 240 mile flush so that you now have 100% new fluid in there. Transmission fluids are really not THAT different. If you did not encounter any shifting problems or errors/codes, then things are just fine.
#2792917 - 11/04/12 04:01 PM Re: Toyota WS vs. Toyota Type 4 fluid [Re: exman123]
MolaKule Offline
Loc: Iowegia - USA
The T-IV is a 7.5 cSt viscosity fluid while the WS is a fuel conserving 6.0 cSt fluid similar to DexronVI. The WS has better cold temp operation, better oxidation resistance, and better friction modifier retention.
I doubt you'll have any damage and as someone else stated, you got a good tranny flush and maybe the dealer will be more careful.
Does the receipt show WS on the ticket and did you see them put in the WS?
Somehow your attitude seems improved after, but not before, my last cup of coffee. smile
#2793058 - 11/04/12 06:32 PM Re: Toyota WS vs. Toyota Type 4 fluid [Re: MolaKule]
exman123 Offline
Loc: NC
Thanks All!!
The ticket states they used Type IV fluid the first time around. That is when I freaked out and I knew it took WS.
On the second time around, I insisted I watch them do the complete flush and I watched them pour in 12 qts of Toyota WS into the flush machine. I am taking it to a different Lexus dealer tomm AM to verify the fluid is full. They did not do the computerized testing to be sure it was full..overfull..undefilled..I am a savy consumer and watch the TSB's. Lexus advised they would pay for this testing.
2005 Lexus GX 470
2010 Ford Fusion SE
