Hi there! I just bought a 2012 2.4 GDI Sonata and I changed the oil from whatever the dealer had to Royal Purple 5w20. In Saskatchewan some winter days can drop to -45 with -10 to -20 being minimum average.
I have a block heater but also plan to get an oil pan heater installed. Summers here can get pretty warm to around 30 above. I just wanted to pick one viscosity grade and stick to it year round.
I do mostly short trips less than 8km drive to work and back with stops at gym. Highway is pretty rare and only about 10%. I have been reading here that GDI engines can cause fuel dilution and it is better to run a thicker grade. The owners manual recommends a 5w20 for better mileage but says 5w30 can also be used for my temperature range.
I plan to change to Pennzoil Ultra to whatever viscosity you folks recommend.RP doesn't seem impressive, they have removed the synerlec additive in their SN oils and Pennzoil just seems like a more trusted and tested brand and has done more research.
thanks
thanks
