Originally Posted By: surfstar
1st off - dude, I thought you were dead?
2nd - I've found it much easier, even with a MTX downward facing fill plug, to just use a funnel + extension, or piece of tubing etc to gravity fill. The one time I was under the car pumping fluid up into the fill hole was the last.
Originally Posted By: bepperb
I agree. I have a funnel with some narrow clear hose, looks like a very small beer bong. Hose is probably 3 feet long, long enough to be comfortably above the engine but short enough that the hose is ridgid enough to make sure it stays in the hole.
It's going to be hard with my truck since the fill port is near the output shaft.
