I wasn't sure where to post this question.
I was wondering if all oils lubricate, or reduce the amount of friction between two parts. I have noticed that thicker oils and grease gives the appearance that friction is increased on very light parts, but those oils and greases must reduce friction under heavy loads otherwise they wouldn't be used.
One time I experimented with different types of oil for machining parts on a lathe and I found that a transformer cooling oil was worse than no oil at all. I know there are many different kinds of oils. Do they all have lubrication properties, or do some increase friction?
