Originally Posted By: dnewton3
Help me out please; I need to understand more. I must confess my chemical ignorance in this topic.
I would concur that lab-to-lab issues might be a concern, as well as any differing methods used to test oxidation. I get that. However, if I understand this thread correctly, both fluids (in this thread by this OP) were tested by the same lab, so both the lab equipment and methods used would hopefully not be in play. IOW - while that topic might be of interest in a Polaris and CAT and Blackstone topic, these two UOAs are from the same place. I would presume that this portion of the topic is moot; it does not apply.
It may not apply to this thread, but it always applies when accumulating data or doing the BITOG UOA section perusal. Completely different scales are used, for example.
That simply leaves us with the starting Ox number topic, right? I'll accept the statement that ester based fluids have a higher starting Ox number, but I would like to know WHY, please. Can you elaborate?
And also, is there a "hard ceiling" limit that Ox should not cross over in a report as a condemnation limit?
If so, would that limit be based on a final magnitude, or rather based upon a delta magnitude shift, or a delta percentage shift?
IOW - looking at these two reports, how does one compare/contrast any SHIFT in Ox relative to a condemnation limit? Do you say that a shift of 50 is the limit, or do you say that the ceiling is 150, and allow either to run up that high? Would you condem a fluid for a "X"% oxidation shift?
How does one know?
If we cannot understand the manner to judge the criteria by, it's pretty much meaningless ...
I made the apparant mistake of looking at them on a level playing field. If that is indeed a rookie error, then help me up to the big-league please!
In simple, concise terms: because of the Oxygen in esters, in simple chemical terms the carbonyl adjacent to the ether linkage - two sets of 0 atoms, that very much have the same wavelength as oxidized carbon chains and such.
Good question on the condemnation limit. Worthy of asking labs and real experts. Depending on the fluid, sometimes I have read "75% of allowable". But what is allowable? I could interpret that to mean virgin + 75%. So and oil with a virgin reading of say 40, condemnation would be 70. I would make it mentionable in a UOA if someone posted a virgin number and it increased 50% or so - start looking for the causes. Excessive heat, malfunctioning breathing system, etc
Indeed rookie error. I have brought up the fact the oxidation number is useless with out a virgin number many times over the years. It would be an good topic for Molakule or other expert to cover here.
