Mech/shop who fixed everything 3 weeks ago said no, only if it starts misfiring.
3.5 weeks ago had my valve cover and all seals for it including gromets, new Irdium spark plugs replaced cause the previous mech didnt install the valve cover properly and ripped the spark seals and was leaking. When he pulled out the coils my coils were soaked in oil but he did his best to dry them off of coil including the inside.
Today, just wanted to check up on things so I pull out my ignition coils and notice theres oil on the bottom of each one. Stuck a flashlight on the insides of each oil and seemed dry so the oil was only on the outside of the coils.
I clean off and stuck a flashlight in the tubes (left the spark plugs inside) and couldnt see any oil sitting at the bottom where the plugs are but very little light smears of oil around the walls of the tubes. So I take a rag dry everything off.
Call back the shop and he says its normal cause the coils were soaked, so over time more oil were release from the coils cause thats what happened when they were soaked in oil. He says dont worry about it unless the car starts misfiring but if it runs good dont worry about it.
My only concern is that if the coils will keep putting out a bit of oil over time then wouldnt that mean oil is getting on the plugs? If so that means they get on the spark plugs = shortening the life of them no?
I told him that ill just check up on the coils a couple more times in the next while and dry off the oil but he said dont cause each time you pull the coils out, you risk them failing prematurely. He said only pull out coils if you have to. Pulling out coils too much is a no no. I didnt know this.
Do you think i should just replace the coils to risk not ruining my plugs? Even though not cheap $200 for all 4 OEM and dont really want to pay that. I could go to a junkyard im sure and get them much cheaper but is that safe?
