This Oil has been in service for 2 years.
Code:
Date Sampled 13-Oct-12
Miles on Unit 39270
Miles on Oil 4530
Oil Brand Mobil 1 TDT
Oil Grade 5W40
Oil Added None
Filter Mobil 1
Metals (ppm)
Iron (Fe) 9
Chromium (Cr)
Lead (Pb)
Copper (Cu) 4
Tin (Sn) 1
Aluminum (Al)
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 8
Sodium (Na) 2
Potassium (K)
Water (%)
Coolant No
Additives (ppm)
Magnesium (Mg) 894
Calcium (Ca) 1300
Barium (Ba)
Phosphorus (P) 1120
Zinc (Zn) 1340
Molybdenum (Mo)
Boron (B) 75
Physical Tests
Viscosity (cSt 100C) 13.8
Fuel %
Soot % Infrared 0.1
Physical/Chemical
Base Number (mgKOH/g) 7.3
Comments: All wear levels appear within acceptable limits. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Fuel dilution satisfactory. Viscosity within specified operating range.
Code:
Miles on Unit 39270
Miles on Oil 4530
Oil Grade 5W40
Oil Added None
Filter Mobil 1
Metals (ppm)
Iron (Fe) 9
Chromium (Cr)
Lead (Pb)
Copper (Cu) 4
Tin (Sn) 1
Aluminum (Al)
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 8
Sodium (Na) 2
Potassium (K)
Water (%)
Coolant No
Additives (ppm)
Magnesium (Mg) 894
Calcium (Ca) 1300
Barium (Ba)
Phosphorus (P) 1120
Zinc (Zn) 1340
Molybdenum (Mo)
Boron (B) 75
Physical Tests
Fuel %
Soot % Infrared 0.1
Physical/Chemical
