I realize part of this topic has been beaten to death (PureONE vs. Motorcraft), and have read threads dating right back to 2002. There's everything from Ford providing the media to Purolator for the FL-820S to the shell on the PureONE only being 0.09" thick.
I currently run an FL-820S on my Ford 4.6, although at one point I have used the Bosch Distance Plus D3410. I know Ford makes a big deal about the bypass, but I never really had any issues with the D3410 over an almost 7,000 mile interval.
I don't really run super extended drain intervals, because of the high levels of sulfur in our gas. Roughly 6,250 miles is the limit. I also replace my air filter at every oil change as cheap insurance (drive in extremely dusty conditions). The Motorcraft is a great filter, there's no doubt. But I'm really looking for more media and a higher rate of filtration. Worth noting, I'm also switching and will be staying with PU Euro 5W-40.
Given the Purolator PureONE and the Bosch Distance Plus, which would be a better option? Neither filter is available locally, so it's going to be a case of either from the States to last me a good while. Thanks!
