Don't confuse flow matching with a simple service job if i'm not mistaken they must have the injectors to perform this task. At least this is true with diesels this could have a great effect on how accurate the injection cycles have on evenly distributing the same amount of fuel on each injector gaining consistency. I would like to know how much the computer compensates for this or irregular dirty patterns their is a chance that internal pulse width modulation will have to have a set parameter to stay with in to maximize the benefits. How about multiple injections per firing?
Its like blue printing an engine you match all the parts and the end result is much more consistent so you have a baseline to work with and it helps smooth things out so you can go faster without unnecessary vibration.
to make a long story short I don't think this is a typical thing that wondervac does on 70$ fuelsystem cleaning.
