'86 Ford F250 6.9L, 2K post overhaul, RT10W30
NW Ohio
Wanted to see how the oil was faring in my 6.9L diesel 2K after an overhaul. It was mostly upper end work, but I replace the rings, pistons (still std. bore) and bearings because I got them for free ( : < ). I am running a bypass system with a 10 um element (I have previously stated 5 um but forgot that I followed the advice of running a 10um if you expect a high level of junk... either cleaning up a dirty engine or after engine work).
I guess you could call this a test of the "factory fill," in this case Rotella 10W30 Triple Protection. The "factory" was me!
I am satisfied with how things are going and will leave this oil in to at least 4K, likely 5-6K, after which it will get Rotella T5, a full synthetic primary filter and a 3um bypass. OCI... TBD. Likely 10K minimum but I will sample at 5K intervals to be sure. I put 2K on this this truck in a year so I am cogitating on how I will factor that into my oil and filter OCI. I have run OCIs out to 3 years with no issues and good UOAs. This is one reason I am switching over to full syn media filters because I trust the media more that cellulose on an extended time OCI.
Left figure is this 2K test/ middle figure unit averages from this truck at 5K OCI with 135K miles/right figure is Blackstone's universal averages for 5K. Zero figures not listed.
Aluminum- 4/4/6
Chromium- 2/3/4
Iron- 33/40/61
Copper- 16/9/6
Lead- 9/7/9
Nickel- 2/1/1
Manganese- 2/1/1
Potassium- 2/3/1
Boron- 20/11/148
Silicon- 21/13/9
Sodium- 5/5/18
Calcium- 2915/3487/2100
Magnesium- 11/11/398
Phosphorus- 1200/1161/1138
Zinc- 1350/1364/1246
cSt @ 100C- 12.73
Flashpoint- 440
Insols- 0.3
TBN- 7.2
Decent numbers; typical after a rebuild. Some escalation is expected until the parts settle into one another.
Should last you indefinitly at "normal" rate of wear, given your low annual mileage.
