This is about the 2001 Dakota in my signature. 2 wheel drive. It has 3 u-joints and a center support bearing on the drive shaft. Over the last few days I replaced all 3 u-joints. I used sealed Brute Force brand u-joints from AAP. I got it all back together very easily, no problems at all really with the installation of the u-joints or reinstalling the drive shaft. The u-joints and trunnion pieces all spin very smoothly. I went for a test drive and did not even make it out of my neighborhood. The truck has a bad vibration from the floor area as soon as I hit 30 mph. If I put it in neutral the vibration is still there, and I feel it in the gear shift knob too. When I hit the brake and slow down the vibration stops.
I did mark the relationship of the driveshaft to the transmission and the differntial before I removed it. I drew a line all the way down the center of the bottom of it and I reinstalled it in exactly the same orientation as it was to begin with.
I did not replace the center support bearing when I did the u-joints. The rubber surrounding it was old but still looked to be in good shape except for the section above the bearing. That part had separated and I could not tell if it was made that way or it had ripped apart. I believe the center support bearing may be bad. If anyone here can confirm that or has more info I would really appreciate the help.
Thanks.
Thanks.
