Originally Posted By: Char Baby
I checked our 4 cars with the Multi-meter. I got readings all over the place.
If I read the coolant from the radiator, I got 0.05-0.10
If I read the coolant from the overflow, I got 0.00
Next cars were all over the map and so-on!
At best, I got reading on every car...0.00-0.05
At worst, I got reading that were bouncing all over and even into the minus.
I made many measurements lately, and found the same thing. When car sits for 6 hours, coolant to ground reads -0.19v, but after another 12 hours sitting, it reads -0.28v. Even at the same time, if I wipe the probe in coolant (positive probe)and re-insert, it would measure a higher value. I once tried to stick two probes in water in the sink, a few inches apart, it reads 0.25v; it also reads 0.5v from water to faucet.
I took out my old analogue meter, it reads zero in water/faucet test. It reads zero from coolant to ground. It only reads a voltage from radiator to ground, which seems to agree with digital meter.
So I've given up the measurement. But I am not denying the physics of electrolysis and galvanic effect. I am relying on the coolant test strips to monitor pH value of the coolant. My car is 12 years old with the original heater core and the second radiator. It's an all-aluminum system. Reason for radiator replacement was not due to corrosion but due to a hair line crack on the hot side tank (plastic) near the fan shroud mount. pH is currently at about 7.2 (fresh coolant is at 7.7, Motorcraft specialty green or Mazda FL-22). Coolant is about 2.5 years.
One thing that's consistent from the digital meter is as follows:
1. Radiator has lower potential than coolant and than ground (block, chasis etc)
2. Coolant has lower potential than ground
3. Coolant has lower potential then heater core
4. Heater core has same potential as ground (not exactly, but voltage is in a few mV's. Resistenct btw heater and ground is 1.3K Ohms).
So I don't have stray current, ground is good. Otherwise coolant would have higher potential than ground.
Heater core and radiator are electrically insulated (no ground). So I am not worried about any galvanic effect simply because the system is an open circuit, like a battery without any external connection between the positive and negative posts. There's potential but no current.
That's it!
