whole hog cook w/ pics
by 04SE
18 minutes 57 seconds ago
redo a/c in 1994 dakota 2wd
by bmwjohn
53 minutes 21 seconds ago
How to post UOA's on here?
by motor_oil_madman
56 minutes 34 seconds ago
Remanns Brand Remanufactured engines
by TiredTrucker
Today at 09:11 PM
Best long lasting door hinges lurbicate ?
by MetalSlug
Today at 08:59 PM
How do you clean trunk area (not inside the trunk)
by MetalSlug
Today at 08:57 PM
Gas prices do the ol' switcheroo
by grampi
Today at 08:44 PM
Possible Valve adjustment needed?
by andrewp1998
Today at 08:16 PM
Hey Dad, can I have some corn syrup, corns starch
by Shannow
Today at 06:47 PM
Idling question
by thunderfog
Today at 06:39 PM
Lodge Sportsman Grill
by hatt
Today at 06:07 PM
2016 Honda Civic factory filter, CUT OPEN
by car51
Today at 05:34 PM
LatitudeDancer, AKN, NickGB, Marcusd1979, emar520
58644 Registered Users
74 registered (AirgunSavant, AZjeff, 2015_PSD, 04SE, ActiveWolf, ag_ghost, 4 invisible), 1575 Guests and 8 Spiders online.
58644 Members
66 Forums
252423 Topics
Page 1 of 2 1 2 >
#2780790 - 10/23/12 04:59 AM UOA article - what is "normal"
dnewton3 Offline
Loc: Indianapolis, IN
Edited by dnewton3 (10/23/12 05:45 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#2780862 - 10/23/12 08:10 AM Re: UOA article - what is "normal" [Re: dnewton3]
A_Harman Offline
Loc: Michigan
Is that an article that you have just posted, or has it been on BITOG for a while? Regardless, thanks for the educational read!
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#2780889 - 10/23/12 08:41 AM Re: UOA article - what is "normal" [Re: dnewton3]
Samilcar Offline
Loc: Iowa
Great article.
#2781094 - 10/23/12 11:35 AM Re: UOA article - what is "normal" [Re: A_Harman]
dnewton3 Offline
Wrote the bulk of it this month on vacation; been in editing and formatting for about a week.
#2781368 - 10/23/12 03:27 PM Re: UOA article - what is "normal" [Re: dnewton3]
ltslimjim Offline
Loc: WatUpDoc
Very nice. thumbsup
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2781508 - 10/23/12 05:49 PM Re: UOA article - what is "normal" [Re: dnewton3]
DanMiller Offline
Loc: Winnipeg Manitoba
Very good article, what oil do you like based on all of the UOAs you have seen ? Are you a thick or thin oil believer ?
#2781539 - 10/23/12 06:19 PM Re: UOA article - what is "normal" [Re: dnewton3]
OVERKILL Online   content
Loc: Ontario, Canada
Excellent article thumbsup
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2781562 - 10/23/12 06:35 PM Re: UOA article - what is "normal" [Re: dnewton3]
JAG Offline
Loc: Fredericksburg, VA
Thank you for the great article, Dave!
#2781611 - 10/23/12 07:12 PM Re: UOA article - what is "normal" [Re: dnewton3]
buster Offline
Loc: NJ
Thanks Dave! thumbsup
#2781850 - 10/24/12 12:35 AM Re: UOA article - what is "normal" [Re: dnewton3]
DanMiller Offline
Since leaving Oil in longer is better for wear numbers would it make sense to change the Oil filter in between Oil changes ?
#2781854 - 10/24/12 01:12 AM Re: UOA article - what is "normal" [Re: dnewton3]
Clevy Offline
Loc: Saskatoon canada
That was a great article. Very enlightening. Wear rates going down as the oil gets more miles was very informative. Thank you for the enlightening information.
2006 Charger RT
Miles x 2 per oil filter
#2782578 - 10/24/12 06:13 PM Re: UOA article - what is "normal" [Re: dnewton3]
fdcg27 Offline
Loc: OH
Really informative.
We here tend to get all excited about small differences in wear metals per thousand miles, but you have put it in perspective.
Maybe the only real use of UOAs is to find gross anomalies, like coolant leaking into the engine oil, or TBN and TAN as well as shear to determine oil life.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#2782700 - 10/24/12 07:50 PM Re: UOA article - what is "normal" [Re: DanMiller]
Quattro Pete Offline
Loc: Great Lakes
Why? Filter efficiency increases with age/miles as well.
Only if you have a seriously sludged up engine that you should change filter more frequently, but then you should not be running extended OCIs either.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2782944 - 10/25/12 01:22 AM Re: UOA article - what is "normal" [Re: Quattro Pete]
HTSS_TR Offline
Loc: Lake Forest, CA
I agree. I'm thinking about leaving cartridge oil filter in the E430 for 2 OCI's of 10-12k miles each OCI. I will inspect the oil filter carefully on the next oil change and re-use it if the filter is in good shape and I don't see any debris. The capacity of the fleece filter is more than 10 grams, it is not possible for the engine to generate more than 2-3 grams in 10k miles.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2782965 - 10/25/12 04:52 AM Re: UOA article - what is "normal" [Re: dnewton3]
dnewton3 Offline
The only way to know for sure it to get some PCs done (particle count analysis).
However, I would contend this; the OEM typically is as conservative with the FCI as they are the OCI.
There are a few notable exceptions. One such example is my (new to me) 2000 Galant with 2.4L engine. The "normal" OCI is 7.5k miles and the FCI is every other oil change, hence every 15k miles. That is with any filter that meets their OEM specs. And there are a whole host of filters from Purolator, Wix, Fram, etc that meet/exceed those specs, right on Wally's shelf. I am not saying all FCIs can be extended that far, but I am saying that as long as your UOA is showing good lube and engine health, the FCI should be able to at least go as long as the OCI. Only if your soot/involubles/oxidation were the drastically escalate in the UOA, would it indicate a need for FCI.
For my vehicles in warranty, (which I'm now down to only one), I am following the OEM criteria for O/FCIs. But for my other stuff, I'm beginning to push even the "normal" OCIs out and using the same filter for that duration.
I am going to put my money where my mouth is, too. I have an upcoming trip out west; we'll be taking my 1995 Villager that has 225k miles on it, and an estimated 6k on the oil by the time we leave. I expect it will have near 10k miles on the lube when we return. I look forward to seeing the UOA when I get back. Am I nervous? You bet I am; I'm always nervous a bit when I try something new. But I have faith in my data streams and SAE studies I've read. This is solid science; just because it's hard to believe, do not make it untrue.
Edited by dnewton3 (10/25/12 04:55 AM)
Page 1 of 2 1 2 >
