I drive a 2011 Ford F150 and use Motorcraft FL-500S oil filters. I've read that one of the advantages of using the Motorcraft filter is the threaded-end bypass valve. I've searched but am unable to determine whether the Amsoil EaO 17 has a threaded-end bypass valve or a dome-end design. Does anyone know? Practically I'm not sure how much it really matters, but a threaded-end bypass does seem to be a desirable feature.
Thanks
Thanks
