Originally Posted By: GC4lunch
Originally Posted By: daves87rs
Lots of votes for maxlife here...wondering-is it a syn blend too?
That is a really interesting question. Our auto transmission specifies a Mazda M-V (Type M5) ATF, which, according to Mazda TSB 05-005/08, is not the same as Mercon V (M-V Type M5 has greater viscosity than Mercon V at low temperatures and a greater judder specification than Mercon V). When we flushed and changed the ATF a few years back, we used MaxLife, which at that time was specified as a Mazda M-V (Type M5) substitute, and said so right on the back label. Came time to change the ATF again this fall, I found that Ashland had removed the Mazda M-V (Type M5) specification from the back label. Further investigation showed that the word "synthetic," which formerly appeared on the front label, now is mising, and that Valvoline's official description of the ATF is:
Quote:
"MaxLife DEX/MERC ATF contains a blend of base oils and a unique additive package to help extend the life of transmissions with over 75,000 miles."
Apparently, in 2008, Ashland/Valvoline changed the formulation of MaxLife to reduce the fluid's viscosity. Valvoline subsequently sent out "to whom it may concern" a letter dated April 2009 over the signature of an executive named Thom Smith that basically says, "ignore the man behind the curtain," but is that letter something that you can take to the bank? The .pdf Valvoline Product Information Sheet downloadable from the Valvoline website dated February 2012 also does not claim that MaxLife is M-V Type M5 compatible, so I find it hard to ignore the man behind the curtain (Wizard of Oz allusion).
As with the deletion of the listing for M-V Type M5 on the back label, so too I wonder whether the deletion of "synthetic" from the front label is a reliable indicator of something going on there.
FWIW, this time around, 2012, we put in Red Line D4 (which is M-V Type M5 compatible) and the transmission shifts more positively and smoothly than it did with the MaxLife.
I noticed this as well. I'm putting MaxLife ATF in the Mazda 3 tomorrow. I'm taking a chance, but after doing some research, this is a top notch ATF and I'm confident it will work well in M-V spec'd transmissions.
I too have heard nothing but good things about the MaxLife ATF. One individual on the Mazda forum noticed significant shifting improvement with this ATF over the OEM. I'm curious....
