Don't use Prestone All Makes All Models in an Asian engine, especially in a Honda. Use either Zerex Asian or some Honda Type 2 (both are 50/50) as mentioned above, if you like concentrate coolant then Peak Global Lifetime is the option.
If you want to DI flush, then refill with concentrate to get it 50/50 properly, then you can use Peak Global or Mazda/Ford FL22/Specialty Green. I went with Specialty Green, as it was the easiest to obtain locally in full strength.
Yeah I have always used Prestone on my 2 previous Hondas with no problem but I might try this Zerex Asian formula next time I will look for it at O'Reillys.
