So my brother wants to replace the old boombox in his garage (contacts failing on analog tuner, snap, crackle, pop, replace it!)
I think i have all the big parts i'll need just lying around the house, save a few bits of wire and easily found connectors, and the final casing/"dress up" pieces
I have a couple units floating around i wanna try.
1) Old Pioneer Gm/Dodge factory fit(DIN & 1/2)
DEH-P85DHR (1998 unit)
Am/FM single cd unit. no aux inputs,not mp3 capable,etc.
"highpower 35wx4"
worked fine when it came out of my 87 Olds when i sold it in 2001. boxed up collecting dust since then. still have the 87 olds harness attached.
2) Kenwood Excelon KDC-X494(bought spring '09)
Am/Fm Single CD, w/ frontside Aux & USB, Bluetooth/Satellite/HD Radio ready(with optional add-on units)
50wx4 MOS-FET
replaced it with a newer, similar unit in my neon, as it developed a habit of rebooting just the faceplate. Started out just every so often if i pressed any button, over the course of 2 years, it got more often, then finally started restarting itself anytime the car would hit the slightest bump. (all sounds like a loose connection between face and stereo, or in the face itself - toying with idea of soldering the connections via cat5 and "remote mounting" the face plate)
200w Power supply harvested from an old PC (depending on which wires i pair can output 5v,12v,17,24v DC)
no power switch on the back of unit itself, has the pc on/off push button switch wired to the PSU, not the MOBO.
2 old speaker boxes(front & Rear WOOHOO!) each w/ (2)6-8" woofers, & Horn Tweeters (Cheap kind you could get pre-assembled pretty much anywhere in the late 90's/early 00's)
my questions so far are thus:
I know the Pioneer has requires both a switched 12v source,and 12v constant (labeled "battery")connection.
I've thought of adding a small battery (motorcycle/powersports/lawnmower type) how should i wire this up power wise? (to feed/maintain battery)
I assume the constant 12v feed is just to maintain memory/clock data, so probably not terribly important for the "bench testing" mockup phase.
also i want to replace the main switch (remote hardwired to the PSU) it's a push button, i wanna use a toggle(or a rocker), there are 4 wires going into the switch(2 in2 out i'm assuming) so...how to wire that to a 2 Terminal toggle(guessing both + to one, both - to the other?), or a lighted 3 terminal(+,acc,-),which i have lying around. would that be connect the negs to each other then to the neg terminal on the switch, then one pos to each of the other 2, or vice-versa, or something completely different?
I'm perfectly comfortable wiring/ soldering, provided i have a diagram to follow. this flying by the seat of my pants stuff makes me afraid i'll blow something up..
"highpower 35wx4"
50wx4 MOS-FET
