Haven't been around in awhile, but I do have a question that hopefully you guys here can help me out with...
"REDUCES EXHAUST SMOKING
USE EVERY OIL CHANGE
Oil burning and exhaust smoking occurs when motor oil enters the combustion chamber and is burned along with fuel. This condition, known as oil blow-by, often results when friction and metal-to-metal contact have worn parts and created gaps between the cylinder walls, piston rings and valve guide seals.
STP® Smoke Treatment provides a thicker oil cushion to help:
* Reduce oil consumption and smoking
* Decrease metal-to-metal contact
* Cushion noisy valves and lifters
DIRECTIONS: Add one bottle STP® Smoke Treatment at or between oil changes. Mix with regular and synthetic motor oils. Satisfaction guaranteed or your money back."
What's in this stuff that reduces smoke?
Notice is says "satisfaction guaranteed or your money back"! Hmmm....
