cold seizure on a small air cooled engine?
by motor_oil_madman
06/30/16 11:20 PM
Walmart.com PUPP 5W-20 $22.47
by mike718
06/30/16 11:20 PM
Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
06/30/16 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
06/30/16 08:39 PM
Firestone TF2876 C&P
by holdorf333
06/30/16 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
06/30/16 08:30 PM
Got to experience cornering ABS today
by LoneRanger
06/30/16 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
06/30/16 08:03 PM
What product was that?
by another Todd
06/30/16 07:19 PM
choice between reciprocating corded saws
by edwardh1
06/30/16 07:04 PM
Is the driving experience getting worse?
by fdcg27
06/30/16 06:24 PM
Scratched wheel
by gabriel9766
06/30/16 05:52 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
62 registered (AirgunSavant, bdcardinal, Bandito440, 2015_PSD, barkingspider, 8 invisible), 1207 Guests and 11 Spiders online.
58322 Members
66 Forums
251064 Topics
Page 1 of 2 1 2 >
#2770629 - 10/12/12 12:08 PM 2005 Honda Civic - NGK Iridium or Denso Iridium Lo
DuckRyder Offline
Loc: Atlanta
NGK Laser Platinum Spark Plug S(PZFR6F-11)
Denso SKJ20CR-A8 Iridium Long Life Spark Plug
For another 100,000 miles?
Any reason to chose one over the other?
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
  • 2012 Volkswagen Jetta TDi
#2770631 - 10/12/12 12:14 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
bourne Offline
Loc: Greenwood, IN
Both are oem/oes recommended plugs. Negligible performance difference or life difference. Whichever is less expensive. Also see if ngk iridium ix are available. They are preforming excellent in my Acura atm. Civic has Bosch iridiums , sort of as an experiment since everyone says don't use Bosch in an Asian vehicle. So far no difference in performance or mileage.
2013 Kia Optima SX-L : Dealer Fill
2015 Chrysler 200S : Maxlife Full Syn 5w20 + CQ 94010
#2770633 - 10/12/12 12:15 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
sciphi Offline
Loc: Upstate NY
What came OEM? IIRC Denso plugs were OEM on our Fit. I'll throw another set of those Densos at it in 30k miles when it hits 80k miles. No complaints about their OEM plugs, since they work fine.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#2770634 - 10/12/12 12:16 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
SuperDave456 Offline
Loc: Dallas, Texas
The platinum plugs are good for 100,000 miles.
The Iridium can go quite a bit longer than that.
I'd figure out what the car came with and stick with that.
On my Taurus after 98,000 miles the plugs looked pretty good. However, the rest of the ignition system needed to be replaced. The Solenoid pack and wires looked pretty bad and I imagine that it was the Solenoid that had given up the ghost. However, I decided to replace the plugs.
Just something to think about.
#2770646 - 10/12/12 12:32 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
Gotch Offline
Loc: Ontario Canada
I'm running IR Fusion in my 06. 100k (km) still running great. Slight increase in throttle response, mileage is a wash.
#2770649 - 10/12/12 12:34 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
DuckRyder Offline
Loc: Atlanta
This particular one came with NGK's but the two plugs listed in the OM/SM are:
NGK: PZFR6F-11
Denso: PKJ20CR-M11
The NGK Iridium Ix Spark Plug (ZFR6FIX-11) is available as well but was under impression that the ground electrode on those is not Iridium.
The NGK's are cheaper but it isn't a huge issue. It is normal maintenance no issues with the car or the rest of the ignition system.
Robert
  • 1972 Ford F100
#2770672 - 10/12/12 01:04 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
bourne Offline
Loc: Greenwood, IN
OEM plug is a double platinum plug. Question here is do you want to put double platinums back in or replace them with Iridiums ?
If double platinum then stick to NGK oem plug.
If Iridium , then I highly recommend NGK IX series #ZFR6FIX-11, with Denso #SKJ20CR-A8 being a close second recommendation.
Here are the links to the home pages of both plugs :
NGK Iridium IX
Denso Iridium Long Life
#2770682 - 10/12/12 01:20 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
Audioquest Offline
Loc: Southwestern Ontario
Although either NGK or Denso can be installed at the factory, I have always liked to run NGK in a Honda and Denso in a Toyota. There are hundreds of horror stories on the net about Bosch plus in Japanese engines, but I have run the standard Bosch Platinum in my 1991 Honda CRX without issue. What seems to be the culprit is the Bosch multi-prong grounded plugs like the +2 and +4 causing misfires. Oddly, my CRX came equipped from the factory with Champion plugs and it never skipped a beat. I now use NGK G-Power Platinums in it.
2011 Toyota RAV4 AWD 2.5
2015 Nissan Rogue SV
1991 Honda CRX Si
#2770713 - 10/12/12 01:49 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
dparm Offline
Loc: Chicago, IL
I ran Bosch plugs for 50k in my Integra GS-R and in my S2000. Not a single misfire code or anything like that. Total hogwash that Bosch doesn't work in Japanese motors.
2011 BMW M3 sedan ZCP
#2770718 - 10/12/12 01:53 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
Chris Meutsch Offline
Loc: Cincinnati
Use the Iridium. I used NGK in my 2001 Civic for 100k runs. Never an issue.
"maybe maroonish? It could be moronish not to change it."
---Egg_Head, 6/21/16
#2770811 - 10/12/12 03:24 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
Mr Nice Offline
Loc: Orlando, FL
NGK with AAP discount code.
2007 Civic EX
2006 Accord SE
2005 RSX base
#2770878 - 10/12/12 04:23 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
wirelessF Offline
Loc: Oahu, Hawaii
You want to use the Denso LL or the NGK Laser Plats/Iridiums for long life operation. They have a platinum ground strap for minimal erosion. The NGK Iridium IX is NOT a long life spark plug since it does not have a plat ground strap. I had them for 40K in my Toyota Tundra V8 and the ground electrode started to erode.
I have Denso LL's in my 02 Chevy Silverado 5.3L, replacing the OE double plats @ 92K. And yes it runs fine despite people saying it need murrrican* spark plugs.
*ACDelco, Champ, Autolite.
Edited by wirelessF (10/12/12 04:24 PM)
#2770883 - 10/12/12 04:26 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
DuckRyder Offline
Loc: Atlanta
Well, had to order them by 4:59 to use the discount code.
Guess we will how the Iridium does, I can always stick a set of the Honda ones in it if I don't like anything about them.
Robert
  • 1972 Ford F100
#2770957 - 10/12/12 06:05 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: DuckRyder]
PandaBear Offline
Loc: Silicon Valley
If both plug model are OEM, then they have tested it when designing the engine / car and have told both companies to adjust / fix any problem found, and therefore should perform close enough and either should work.
Other brands may also work, but since it is only tested by the plug manufacturer and not the car manufacturer, you'll never know how much of a difference (if any) it is making.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#2771010 - 10/12/12 07:17 PM Re: 2005 Honda Civic - NGK Iridium or Denso Iridium Lo [Re: dparm]
antiqueshell Offline
Loc: chicago, Illinois
Exactly, this is internetz rumor mill nonsense.
Now granted it is true that GENERALLY you should stick with the same number of ground tips that came with your car. However in many cases even this is not an issue, as I know of MANY models that have identical engines in a number of markets yet each market will specify different plugs with a different number of ground tips.
ACTUALLY THE MOST CRITICAL SPARK PLUG SPECS ARE
1) Thread pitch
2) Length of plug in combustion chamber
3) Heat range
The others are less critical
4) Number of ground tips
6) Electrode metal and or design
5) type of metal
I think NGK has a vast viral marketing arm that flood DIY sites like this and push NGK with various claims, all of which are dubious at best.
Edited by antiqueshell (10/12/12 07:20 PM)
Page 1 of 2 1 2 >
