Originally Posted By: riff1006
I've used brake cleaner, a rag, and a toothbrush with good results.
I'd be careful using brake cleaner. Some vehicles have a Teflon coating on the throttle plate and brake cleaner might remove that. Regular carb cleaner should not be used for the same reason. Also, brake cleaner doesn't contain any lubricants, whereas dedicated TB cleaners do.
