All, my uncle recently advised me that no matter how well it is pulling, not to pull on terrain that is not level in overdrive. My truck has 4.56-1 gears in the back, and recently pulled a 2000lb camper while hauling 5 people, three dogs and a bed full of camping gear (probably 1500 pounds) with no issues. It pulled up hills in OD without hunting a bit,and did not need a lot of gas pedal to do it. On his advice I locked out OD and kept it locked out after that little experiment. It obviously pulled very well in 3rd, but RPMs were on the high side (2900 at 55mph). Mileage was OK (15.5MPG). I want to keep RPMs under 3K, but would like to go a bit faster, so if I can pull at 65MPH at about 2400-2500RPM in overdrive that would be awesome. Opinions? Facts? Thoughts? To all the guys that commented on my previous post about gear selection- if I had it to do over again, I would probably run 4.10s.
