Here's an interesting test made way back using 3Rx (the industrial version of Auto-Rx - same ingredients).
"I received the sample you sent me. While you believed it to being a
better product than any other similar product, I decided to test
your claims. To accomplish this I developed a battery of tests to
compare your 3-RX against some commonly available consumer
automotive products (Greased Lightning, STP, Slick 50 and other so
called friction reducers). I designed and built the tester specifically
for these tests utilizing the following equipment:
· Small AC motor and controller
· Bearing Block w/608Z bearings. (Cheapest I could find)
· Custom made adjustable motor mounting system.
· 1 Temperature Sensor
· 1 Ultrasonic Vibration Sensor
· 1 Accelerometer."
The balance of the test can be found in the following link.
http://www.3-rxlubricationsystems.com/DSO-3RX_Testing.PDF
[ July 29, 2004, 03:36 PM: Message edited by: LarryD ]
· 1 Accelerometer."
