Hello, I am a first time poster but long time lurker here on BITOG. I apologize if this has been discussed before but my searches were not turning up anything. In the manual for winterizing my ’07 Mercruiser 4.3 it is recommended to unhook the fuel line and run the carb dry before storing for the winter. I have been doing this by just unplugging the electric fuel pump and running it dry that way. I am torn on whether running the carb dry is really a good idea or not as it seems this would leave space for condensation (although I am in a dry climate) to take place and let seals dry out. Also it is very hard to time the fogging right so you are getting a good amount of fogging oil down the carb when it is getting ready to run dry.
Seems like it would be better to just treat the fuel, run for a bit, then fog er up. I have also contemplated dumping some 2 stroke or fogging oil in the fuel filter/water separator (how much?), then running it until it starts smoking, then unhook the fuel pump and run it dry.
Anyone have any insight?
Thanks.
Thanks.
