All analysis done by Blackstone Labs
UNIT ID: 08 RAM 2500
OIL REPORT DATE: 9/19/2012
Cummins 6.7L OIL TYPE & GRADE: Valvoline Premium Blue 15W/40
Diesel FUEL TYPE: OIL USE INTERVAL: 10,086 Miles
Oils: VPB /Unit Ave./CTE/VPB/CTE/VPB/CTE/Univ.Ave (Castrol Tection Extra)
COMMENTS: This oil was in use 10,000 miles, but the engine handled it very well indeed. Iron is the only metal noticeably higher than last time, but that metal tracks with time on the oil, so it's not really a concern. Plus, wear metals are looking good compared to universal averages and the other metals stayed low and flat. No fuel or coolant showed up in the oil and air and oil filtration are fine. The TBN was 4.1 showing lots of active additive left; less than 1.0 is low. This engine could honestly handle 12,000 miles on the oil, but 10,000 is working well. Nice report.
ELEMENTS IN PARTS PER MILLION
MI/HR on Oil 10,086 Unit Aver. 7,240 6,278 7,250 7,028 6,657 Univ.Ave.
MI/HR on Unit 95,984 UA 85,898 78,658 72,380 65,130 58,102 UA
Sample Date 09/10/12 UA 03/02/12 10/23/11 06/20/11 11/29/10 08/16/10 UA
Make Up Oil Added 0 qts 0 qts 0 qts 0 qts
ALUMINUM 3 3 2 2 3 3 3 3
CHROMIUM 1 1 1 1 1 1 1 1
IRON 17 15 11 10 15 14 16 24
COPPER 3 2 1 2 2 2 2 7
LEAD 2 1 0 2 1 0 1 1
TIN 1 2 5 0 0 0 0 1
MOLYBDENUM 89 61 319 44 6 28 1 36
NICKEL 0 0 0 0 0 0 0 0
MANGANESE 0 00 0 0 0 0 0
SILVER 1 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0 1
POTASSIUM 5 2 2 0 0 5 0 6
BORON 8 27 51 12 39 6 35 47
SILICON 3 4 4 3 2 3 4 6
SODIUM 7 7 8 6 9 1 4 4 6
CALCIUM 1535 1995 2356 1436 2144 1375 2562 1578
MAGNESIUM 830 328 103 851 92 725 6 572
PHOSPHORUS 1138 1088 1116 1217 1059 1053 1056 1001
ZINC 1380 1241 1217 1356 1205 1000 1340 1179
BARIUM 0 00 0 0 0 0 0
PROPERTIES
SUS Viscosity @ 210°F 71.7 69-78 70.4 73.9 68.7 69.2 70.4
cSt Viscosity @ 100°C 13.41 12.7-15.3 13.06 13.97 12.62 12.74 13.05
Flashpoint in °F 440 >390 430 415 410 410 430
Fuel % Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Water % 0.0 Insolubles % 0.4 TBN 4.1 >1.0 (1st TBN done on my oil samples)
Additional note: The high MOLY(319) was an oil additive. CTE has no MOLY.
TIN 1 2 5 0 0 0 0 1
PROPERTIES
