Magnatec 5w30 - Push Mower
by SavagePatch
05/06/16 11:31 AM
RAM 1500 EcoDiesel filter
by pb379
05/06/16 09:14 AM
Motul 8100 X-Cess 5W/40 11,568Miles BMW335i
by strongmad
05/06/16 08:52 AM
Lawn Tractor Utility Upgrade
by bigdreama
05/06/16 08:50 AM
Help with iphone on the home network
by buck91
05/06/16 06:45 AM
2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
86 registered (agpatel, 15SilvyEcotec, AirgunSavant, Alfred_B, Al, 901Memphis, 7 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248543 Topics
Page 2 of 2 < 1 2
#1811156 - 03/10/10 06:55 AM Re: Cheat sheet for newbies reading UOA's [Re: TucsonDon]
widman Offline
Loc: Bolivia
Boron is basically an anti-oxidant Has some anti-wear in different cases. You won't see a decent group I oil without it, but it can often be left out of group II, group III, or traditional synthetics.
Here is one of the most complete wear metals charts I've seen in a while
Wear Metals guide in PDF
Richard's Car Restorations
#1852888 - 04/11/10 07:42 AM Re: Cheat sheet for newbies reading UOA's [Re: widman]
CourierDriver Offline
Loc: USA
I like the report, Im gonna get a degree in chemistry someday. Im glad someone out there knows how to make all those elements stay together for 500k miles. Me, I just want it to run right, bottom line. amen
Look at your check book and see where your priorities are...
#1853472 - 04/11/10 05:38 PM Re: Cheat sheet for newbies reading UOA's [Re: CourierDriver]
Steve S Offline
Loc: East of IGO
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1897854 - 05/20/10 06:07 PM Re: Cheat sheet for newbies reading UOA's [Re: Steve S]
widman Offline
Loc: Bolivia
One more thing. A lot more engines are being assembled these days with Moly rings. Ring wear will show up as or with the moly that might be used as an antiwear/antioxidant.
Condemnation limits vary per engine and engine construction. Those that are published (CAT, Cummins, Detroit, etc.) are extremely high and not close to what is obtainable.
#2333676 - 07/31/11 10:06 PM Re: Cheat sheet for newbies reading UOA's [Re: Bambam]
sm00thpapa Offline
Loc: Spring Hill, FL
This is not bad but what about what the numbers mean? I mean is a high number or low number better for each category?
16 Sonata Sport
16 Elantra SE
09 FZ6R
04 Ascender
96 Cavalier
#2389160 - 09/27/11 07:42 AM Re: Cheat sheet for newbies reading UOA's [Re: TucsonDon]
mongo161 Offline
Loc: Coney Island, NY
Originally Posted By: TucsonDon
I think Boron is becoming part of the additive pack of some oils ... Rotella CJ-4 comes to mind as having increased the Boron.
+1 After looking at some VOA results on different oils, PCMO and Diesel, BORON is becoming more of an additive in Synthetic and Dino oils.
I get by with a little help from my friends....listen with your eyes....it's the ONLY way to believe what you hear...
#2658196 - 06/19/12 12:34 AM Re: Cheat sheet for newbies reading UOA's [Re: Bambam]
ARHND Offline
Loc: Honduras
How about the different tolerances of each equipment. All factories have their own, so, to be sure of each UOA you should also know the different allowances or minimuns.
#2757895 - 09/29/12 08:48 AM Re: Cheat sheet for newbies reading UOA's [Re: RWEST]
skyship Offline
Loc: Tettnang, Baden-Wurttemberg, G...
Originally Posted By: RWEST
So, to help out an oil-dork, what should the numbers be for a multi-vis, say, RTS 5-40? confused
Blackstones will give averages for most engine types for you to compare results to. For a 1.9 TD I would not be too concerned until the Iron was over 50 ppm, Aluminium over 10, Chrome or Lead over 5 and Silicon from the air filter over 20.
The 5W/40 figures for a UOA are as follows:
SUS Vis at 210F: 66 - 78
cSt Vis at 100C: 11.9 - 15.3
Flash in F: > 410
Fuel % < 2
Antifreeze: 0
Water% < 0.1
Insolubles: < 0.8
TBN: > 1 (Normal) >3 (Severe service)
The trend is as important as the actual figures for wear metals, as every engine is subject to different use and to complicate matters you might have a temporary particle streak occur and rebuilt or new engines produce different figures.
The car should be driven at normal speeds for half an hour plus before draining the oil and the sample taken mid stream into a clean container.
Edited by skyship (09/29/12 08:58 AM)
Page 2 of 2 < 1 2
