Originally Posted By: antiqueshell
Originally Posted By: Zako2
The factory recommended ATF change interval is 150,000 miles. Would it be a waste of time and money to change the ATF at 80,000 miles?
DO NOT WAIT ANY LONGER. DO THE CHANGE NOW!
While Ford claimed they could go that long they most certainly will fail early if the fluid is not changed around 50k-60k mile intervals.
Use ONLY the Mobil 3309 if you want to be very safe, but it is likely true that the Toyota T-IV
is the exact same product. No one knows FOR SURE that the Toyota product is exactly the same, but considering that the Asin transmission found in the 500 is the same as some Camry. It is likely a safe bet.
BTW my father has the same model 2005 Ford 500.
A service writer I am good friends with at the Ford store(used to work with him at a Honda store) told me that it was a good idea to get that fluid changed at least every 60k. As there had been problems with the extended interval causing drive-ability and failure issues. .
how about the
6F trans in the 08-09 Tauri(Tauruses?)
similar recommendation on fluid intervals (~150k)from Ford. what are the "real world figures" (mom bought a Ford Certified '09 this Feb w/ 35k miles on it...)
