Rotella for 6.0L Gasser
by Joefuskie
04/29/16 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
04/29/16 04:21 PM
TGMO 0W20 7700 miles UOA
by micmac
04/29/16 03:45 PM
"Low Coolant" light doesn't vanish.
by OpenClose
04/29/16 02:07 PM
Is running "Engine flush" before a change legit?
by OpenClose
04/29/16 01:59 PM
Who Owns A Beater?
by Red91
04/29/16 01:09 PM
What prevents pics from being viewed on posts?
by daves66nova
04/29/16 12:42 PM
QS Filter Miles
by Yup
04/29/16 12:23 PM
Denso Irdium plug at 68k miles
by SHOZ
04/29/16 12:19 PM
Chrome bumpers from RockAuto. Good quality?
by mrsilv04
04/29/16 12:00 PM
Krown Rust Proofing illegal in U.S.
by Warstud
04/29/16 11:49 AM
fixing the t/a
by turtlevette
04/29/16 10:55 AM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
74 registered (1JZ_E46, AZjeff, 4wheeldog, 2015_PSD, 4Scott4, 9 invisible), 1844 Guests and 103 Spiders online.
57738 Members
66 Forums
248220 Topics
Page 2 of 2 < 1 2
#2610892 - 04/26/12 10:00 PM Re: Mobil Super High Mileage vs. Valvoline MaxLife [Re: Jeffy_D]
volk06 Offline
Loc: Iowa
Originally Posted By: Jeffy_D
FWIW I used Mobil hm last year, good winter hm oil, fast starts, didnt consume oil, kept my valve stem leak mostly in check. Its sn rated, and it seemed to get good mpg for a hm oil, but doesnt quiet the valvetrain as well as maxlife does in most vehicles. Its rated for up to 7500 miles, maxlife says 5 max.
Id say maxlife when weather.is warm, Mobil super when its colder when prices are same or close.
If thier is a deal for either one, grab the cheaper.
Mobil super and Mobil super HM are guaranteed for 5k. Only Mobil super synthetic has the 7.5k oci rating from Mobil in the super line up.
Edited by volk06 (04/26/12 10:02 PM)
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#2610932 - 04/26/12 10:41 PM Re: Mobil Super High Mileage vs. Valvoline MaxLife [Re: volk06]
Jeffy_D Offline
Loc: missouri
I guess in my head I assumed it lasted as long as its predecessor,Mobil clean 7500. Its getting hard to keep up with the changes the oil copanies make . My mistake.
And I thought when next gen first came out, it was sm rated while white and red bottles went to sn, which caused a reduction in moly. either way, I preffer using the green bottle, seems a lil thinner, I like that its been double refined. Doesnt fly off the shelf like red bottle, so its always in stock wink
10 titan 70k castrol magnatec/fram TG
12 sonic 55k AC Delco oil and filter
#2610970 - 04/26/12 11:50 PM Re: Mobil Super High Mileage vs. Valvoline MaxLife [Re: Jeffy_D]
RamFan Offline
Loc: Illinois, U.S.A
The local Walmart doesn't even stock NextGen anymore, they've got some 5w20 on clearance for 3.50 a quart.
06 Monte Carlo LT
+3.9l V6 - 175k - Super S Multi-Flo 5w30 - Napa Silver - OLM
16.5 CX-5 Touring
+2.5l I4 - 4k - Mag1 0w20 - Mazda - OLM
#2610989 - 04/27/12 01:42 AM Re: Mobil Super High Mileage vs. Valvoline MaxLife [Re: RamFan]
Zako2 Offline
Loc: Texas
Right now you can get the Valvoline NextGen version of Maxlife from O'Reilly and AAP effectively for free, after $20 mail-in rebate. Check the promotions forum for details. In fact, you can grab 1qt bottles if you want. Because of this promotion, I'd say grab 10 quarts, apply for rebates, and use the oil. Then use the money you saved through the rebates to produce used oil analysis reports. Maxlife Nextgen is effectively the same quality oil as Maxlife Conventional. I have been impressed with a couple of Maxlife/Maxlife NextGen reports I have seen recently. It looks like you can go 7,500 miles easily on it, unless you're engine is harsh to its oil. The only problem is that you can only get 5W30 or 10W30 weight of Maxlife NextGen from any retail store. It seems like the 5W20 weight is not available, except through Amazon or Walmart by special order.
Edited by Zako2 (04/27/12 01:46 AM)
#2614325 - 04/30/12 09:58 PM Re: Mobil Super High Mileage vs. Valvoline MaxLife [Re: bourne]
LeakySeals Offline
Loc: MA
You mean valve seals? The HM oil would swell the seal around the stem. Thats good to know, I have that problem too, thanks.
Maxlife does NOT have seal swelling addpack , its actually seal conditioners. They made a big deal about it and recommend maxlife for use in a brand new car as well. Regardless , there is a change coming soon from Ashland I believe ......
Interesting. Maybe that explains why M1 HM worked so much better for me than maxlife. M1 openly admits swellers, uses the word in the M1 FAQ.
02 Camry XLE 2AZ-FE 345k M1 HM 5w30
06 Escalade 132k. M1 0w30
#2639531 - 05/29/12 05:46 PM Re: Mobil Super High Mileage vs. Valvoline MaxLife [Re: RamFan]
buster Offline
Loc: NJ
It's often a diester they use to swell the seals slightly.
Quote:
Features and Benefits
Helps extend engine life
Contains seal conditioner to help prevent or control leaks and reduce oil consumption
Helps protects older engines
Guaranteed protection with the Mobil Super Limited Warranty*
Outstanding wear protection under a wide variety of operating conditions
Easy cold starting.
Meets or exceeds the latest industry specifications
API SN / Resource Conserving (Mobil Super High Mileage 5W-20, 5W-30 and 10W-30)
#2755734 - 09/26/12 09:58 PM Re: Mobil Super High Mileage vs. Valvoline MaxLife [Re: RamFan]
The Critic Offline
Loc: Walnut Creek, CA
Here is something to consider as well: the ILSAC GF-5 and resource conserving designations.
The Mobil Super High Mileage oil is the only mass-produced high mileage oil to be fully API SN, ILSAC GF-5 and Resource Conserving satisfied. These three items can be quite important for vehicles still under warranty. Most high mileage oils are only API SN certified and not OK for resource conserving or ILSAC performance requirements.
11 Prius - 126k - M1 EP 0w20/OE
07 Accord 2.4 - 109k - M1 5w20/FPS Filter
10 Altima 3.5 - 33k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
Page 2 of 2 < 1 2
