Also, there is a coolant sensor that will need to be taken out and pluged on the rear drivers side of earlier91 thru 95 7130 heads. 0630(96 thru 98) heads have this as well, but 99 year 0630 heads do not have this. Also your 2000 block will have two alignment dowels on the passenger(lifter) side, one at front one at back, so depending on what year head you replace it with, some material will need to be ground away so alignment dowels wont push cylinder head out of alignment. Alabama Cylinder Heads, ClearWater Cylinder Heads or Late 2002 thru 2006 TUPY stamped 0331 cylinder heads would be the easiest and maby best replacement.
