A few pics from installing an overdrive in the LR. I occasionally drive this on the highway and the OD gives a ~30% reduction in RPM and reduces fuel burn and noise. May also extend top speed but you probably d/n want to go much beyond 60mph in one of these.
Neat view of the transfer case showing the straight cut low range gears, selection mechanism and transmission brake. In the top pic, the transmission (front) is to the left and the OD uses a co-axial gear to take the input into the shaft in the gear center and step it up to the outside output gear you see below.
