ALL piston engines consume at least a small amount of oil. There's no such thing as an engine that "doesn't use any oil." The engine sprays oil on the cylinder walls when the piston is at the top of its stroke to lubricate the rings and piston skirt. When the piston comes back down, the oil control rings scrape a controlled amount of oil off, leaving a very thin film to lubricat the upper compression rings. Part of that thin film gets burned away when the cylinder fires. Nature of the beast.
In a very healthy, tightly-built, mildly tuned engine, that consumption will amount to well under a quart in 6000 miles- my 150,000 mile Cherokee, for example, never needs a quart between 6000 mile changes, and is only down about a cup.
Engines with more piston ring length- big-bore v8s for example- tend to burn more. Little 4-poppers burn much less, all other things being equal.
Some engines are also naturally "looser" than others and can burn a more oil past the rings- high-performance engines for example. Wear will eventually cause a drastic increase in consumption past the rings, as can using the wrong grade of oil. Too thick can cause more consumption past the rings as easily as too thin. When the oil is too thick, the oil control ring can't "scrape" it all away leaving a thicker layer to get burned off.
Another source of consumption already mentioned is the valve guides- like rings, they need to be supplied with oil and at least a tiny part of that oil gets lost when the valve is open and the intake charge washes it off the valve stem or the exhaust gasses burn it off. When the guides wear or their umbrella seals break down, consumption goes up.
Finally, one of the biggest source of consumption can be the PCV system. If there's not a good system to separate oil mist from blow-by vapor, then that mist gets sucked into the intake and burned.
