What do you guys think of this oil pros/cons? Is this oil a polyester or diester oil? Im looking for a quality syn lubricant to be used in a strictly racing application to provide good thermal and wear protection. Here is my application:
New 331 SBF stroker (all roller).I just completed a dyno tuning session at JBA racing here in SD,CA where it made 490 HP @ 6800 RPM, max torque 415 @ 5900 RPM, EEHAW! I used Kendall 20-50 W/ Liquid Titanium ( not synthetic)for the break in, made 12 pulls so the motor should be completly broken in. The bearing clearances are: 0024 @ the rods and .0026 at the mains. The oil capacity is 12 quarts (the pan,#12 oil lines,oil cooler). The application is road racing where I typically see oil temps of 200-270F (sensor in the pan) so temps at the bearings will be higher. The numbers on the PDS look pretty good. Thanks Mike
