The engine was rebuilt about a week ago on this '97 Suburban, but there's a misfire on cylinders 2, 7 and 8 (verified by a GM Tech 2). The misfire is worst on cylinder 7.
The tech reckons it's either the distributor cap or the fuel injectors, but I was wondering what else could be a likely cause. Worthy of note, this is an export vehicle and does not come with catalytic converters or oxygen sensors either. The exhaust reeks and idle is slightly rough, although not too bad. The truck shivers as you take off though.
This has been an issue before the engine was rebuilt. The plugs and wires are all new, as is the fuel filter (all ACDelco). The MAF has been cleaned, and tested ok and there are no codes stored in the PCM.
