Probably need a new battery soon. My car can take either, but looking at the specs, the smaller 26r looks better and that's what I'm leaning towards. Any reason to take a bigger bodied battery?
Battery Type: Lead Acid
BCI Group Size: 35
Cold Cranking Amps: 500 amps
Cranking Amps: 625 amps
Deep Cycle/Starting: Starting
Height: 8 13/16 in
Length: 9 11/16 in
Maintenance Free: Yes
Reserve Capacity: 80 min
Terminal Type: Top Terminal
Voltage: 12 v
Weight: 34 lbs
Width: 6 7/8 in
BCI Group Size: 26R
Cold Cranking Amps: 575 amps
Cranking Amps: 720 amps
Height: 7 3/4 in
Length: 8 1/2 in
Reserve Capacity: 81 min
Voltage: 12 v
Weight: 29 lbs
Width: 6 3/4 in
BCI Group Size: 35
Height: 8 13/16 in
Length: 9 11/16 in
Voltage: 12 v
Weight: 34 lbs
Width: 6 7/8 in
BCI Group Size: 26R
Height: 7 3/4 in
Length: 8 1/2 in
Voltage: 12 v
Weight: 29 lbs
Width: 6 3/4 in
