Just put a new water pump and radiator in this thing last weekend, now it wouldn't start this morning for my wife. Dang it.
There is juice in the car (interior lights come on, radio works, etc). Just when you turn the key....nothing.
Put a volt meter on the battery...only about 10 volts. So, I put a battery charger on it this morning. I'll check it after work when I get home.
The battery looks like a fairly cheap model. It's 3 years old according to the born on sticker. The guy I bought it from must have put it in right before he sold me the car.
How do I tell if it's a bad battery or a bad alternator? With my last repair bill, I don't have the money to simply replace both battery and alternator. How do I know if the battery won't hold a charge or if the alternator isn't charging it?
IF I can get the car started, can I simply disconnect the battery while running and see if the car shuts off...and if it does, the alternator is therefore bad? Someone told me this might work.
I just want to replace what needs to be replaced and not go further into debt over repair bills on unnecessary parts.
Thanks in advance.
Thanks in advance.
