Any HR specialists out there?
by bustednutz
05/24/16 06:23 PM
Jawa 350/360 (two-stroke) motor oil
by volodymyr
05/24/16 05:52 PM
Red Line 20W60 Synth. 1k Miles '13 KTM DUKE 690
by albertdi
05/24/16 05:49 PM
Tire Suggestions - 2014 Dodge Grand Caravan
by Nick1994
05/24/16 05:38 PM
Completing your 80% lower receiver manually
by Merkava_4
05/24/16 05:18 PM
5.4 3V VCT solenoid replacement
by 04SE
05/24/16 05:11 PM
Changed the spark plugs on Sunday, and [censored]??
by SirTanon
05/24/16 04:46 PM
Fram Ultra XG10060 Cutaway...
by AnthemBassMan
05/24/16 04:11 PM
The Vole (MS) now deceiving users to install W10
by simple_gifts
05/24/16 04:04 PM
5w20 + seafoam + hot weather + towing = ?
by meborder
05/24/16 03:15 PM
Chewbacca Mom & James Corden
by CharlieBauer
05/24/16 02:45 PM
This Radiator Looks Good to Me!
by Miller88
05/24/16 02:38 PM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
90 registered (Barwich, 04SE, AnthemBassMan, albertdi, Atesz792, aquariuscsm, 8 invisible), 1771 Guests and 123 Spiders online.
57966 Members
66 Forums
249359 Topics
#2737810 - 09/08/12 01:12 AM Passat 1.8T G-Oil UOA history
zanzabar Offline
Loc: NorCal
Fourth UOA on G-Oil from my 2002 Passat 1.8T. Driving is mostly short trips with occasional 15-50 mile weekly jaunts. All four samples were taken from drain plug on the sump and less than 1qt was drained in total each time, sump capacity is 4qts so that amounts to 25% replacement each sample. See the end for adjusted quantities of wear metals that take this into account. Topup oil was <1qt G-Oil following each of the first three samples, plus ~1/3qt RotellaT 15-40 after the third one - no doubt many of you will note the effect on additives, TBN, and visc!
Code:
miles	  5500	3500	1500	50
ALUMINUM  4	4	2	1
CHROMIUM  0	0	0	0
IRON	  8	4	3	1
COPPER	  7	5	4	2
LEAD	  0	0	0	0
TIN	  0	0	0	0
MOLY	  58	63	62	61
NICKEL	  0	1	1	0
SILVER	  0	0	0	0
TITANIU	  0	0	0	0
POTASSI	  4	8	0	0
BORON	  78	118	126	155
SILICON	  64	54	29	10
SODIUM	  3	0	0	0
CALCIUM	  1910	1740	1823	1729
MAGNESI	  87	122	158	116
PHOSPHO	  771	716	718	644
ZINC	  824	709	741	759
BARIUM 	  0	0	0	0
V210F	 unkown	unkown	55.3	57.8
V100C	  9.5	8.6	8.86	9.6
Flash	 unkown	unkown	360	415
Fuel%	 <0.5	<0.5	TR	<0.5
Antifrz	 0	0	0	0
Water %	 unkown	unkown	0	0
Insol	 0.1	<0.1	0.3	0.2
TBN	 2.9	2.1	5.6
If you adjust the wear metals to account for 25% reduction every sample you get Aluminum/Iron/Copper of 5/9/8.
2007 Volvo V70 (115k miles)
2014 Ford Focus (14k miles)
#2737815 - 09/08/12 01:22 AM Re: Passat 1.8T G-Oil UOA history [Re: zanzabar]
zanzabar Offline
Loc: NorCal
First two samples analyzed by Blackstone, the second two by whoever does the Wix analyses (in Portland).
Not entirely sure what's up with the silicon, but I think it's most likely from new valve cover gasket and replacing a large portion of the PCV hoses with silicone.
#2738167 - 09/08/12 04:03 PM Re: Passat 1.8T G-Oil UOA history [Re: zanzabar]
71Chevyguy Offline
Loc: Martinsburg West Virginia
Looks like it did pretty well in a car that is known to be pretty hard on oil. I am doing an 8k run on G-oil in my Saturn Ion and may do a UOA for those of us here that are keeping an eye on the G-oil results. Looks like a decent oil, and FAR it can't be beat for short intervals if you do not believe it can handle more of a run. Looks like it did well in the Passat though.
15 Chevy Sonic RS QSUD / Delco filter
85 Buick Skylark 2.5 VNGHM / PF52
87 Caprice 305
71 Nova 250
#2739053 - 09/09/12 06:09 PM Re: Passat 1.8T G-Oil UOA history [Re: zanzabar]
tstep Offline
Loc: PA
It doesn't seem as though the high silicon has had an adverse affect on the wear numbers. Are you running an oversized filter? I insalled a Purolator L40316 (it is a rebadged Mann 950/4) and that added about 5/8-3/4 quart of capacity. Appreciate the G-Oil UOA.
#2739262 - 09/09/12 11:45 PM Re: Passat 1.8T G-Oil UOA history [Re: tstep]
zanzabar Offline
Loc: NorCal
Nope, just a normal sized Mann W719/25.
