Originally Posted By: addyguy
For 7 quart sump, and 'only' 5 months/11k, I'd say this is a pretty darn poor showing for EP.
Look good to me, not stellar (like some M1 0W40 reports), but still ok. The 7 quart sump does not imply that oil will be beaten up less than in cars with a smaller sump. A 2.0 Mitsubishi engine has a 4.3 quart sump, but obviously the lubrication needs of a 2.0 I4 engine are far lower than those of a V8 with 4.6L displacement. The TBN still doesn't look bad and should stay above 1 for a while as its depletion is likely non-linear. There is also the issue of the duty cycle. 15,000 miles is "best case" scenario for an engine not seeing severe duty usage.
