I just changed the rotors and pads on the front of my '99 Corolla. When I got done I took it for a drive. Right off the bat I noticed the brakes felt like they were dragging. I drove the car around the block and then got out to check the brakes and they were litrally smoking they were so hot. Even though I thought this was only to set the brakes on drum brakes, I tried backing up and hitting the brakes hard a few times, but they still feel the same. Is this something that will correct itself, or there something I need to do to correct it? And yes, I cleaned the new rotors off with brake cleaner before I installed them...
