This question is about my 2001 Dodge Dakota, 3.9 V6, manual 5-speed with about 150,300 miles on it. Week before last I went on a trip about 45 miles out of town, mostly all highway driving. I had the A/C on cold, blower fan on high speed. When I got to my destination and stopped at a red light, I noticed my A/C blower fan slowed down. I made my turn at the light, RPM's went up, and the fan speed/output went back up to normal. Came to a stop sign, fan slowed back down again. I have a voltmeter in my dash, I saw no odd or abnormal voltage fluctuations or low voltage readings. My battery is in good shape, it's a Duralast Gold and is not even 3 years old yet. My truck is in great electric and mechanical shape and runs very well for its age.
I have not driven my truck very much since that trip but the blower motor problem is still present when I do drive it. At normal driving speeds the blower works fine, if I stop at a light or stop sign the fan speed and output slow down by about 30 to 40%. I think this is a sign my blower motor is about to quit working altogether.
I guess I should also say this the original factory-installed OEM Mopar blower motor that I have on my truck. I already replaced the blower motor resistor pack about a year ago. When that happened, I still had all 4 fan speeds, but the lowest and next speeds were a bit slow to kick on when I turned the knob. It would take a few seconds to get any output at all from the AC or defroster if the system was off and I only turned it to low or the next highest speed. In other words if the system was completely off and I turned the fan knob only to the first or second fan speed, there was a pause of about 10 seconds with no air output at all, then the system would have normal air flow. I bought a new resistor pack at AAP (I know it is not OEM Mopar but the parts both look exactly the same and AAP is right up the street), swapped it out and that fixed the slow fan speed problem right away.
Thanks for any help here.
