The R's original battery is now 7+ years old. As a precaution, we're retiring it before this winter - keeping it as a desulphated/tendered emergency spare.
For replacement, there are options. We're going dealer, as I have some "loyalty cash" to burn, so the final price will be cheaper than anywhere else.
Virtually all VCNA P2s come factory fitted with the standard size Volvo batt. -- an H6 600cca/70ah.
The standard H6 is also what runs on the earlier engine compartment mounted 850/V70 models.
At your friendly dealer (or parts store), they will almost always hand you the standard replacement H6 for any later Volvo. (Volvo part no 30772221). It's quick, easy and fits almost all of them.
A few years ago, you could get a Varta made in France standard Volvo batt. They really last - as the one in our 855 is now going strong on 8+ years, and the OE one out of the R is still testing good, too.
But all the new Volvo-branded standard batts in the US are now Johnson Controls made in Mexico and Interstate-distributed to Volvo -- even though the Volvo label says "made in Germany". Maybe the label is made in Germany. The Volvo standard batt is pretty much the same Interstate you can buy at the auto parts store for $30 less.
But most of the trunk-mounted P2s can also accommodate the HD H8 800cca/90ah option (usually reserved for Euro-market diesels). The battery tray has the extra length and hold down hole for it. Not all US dealers know and/or will tell you that.
If you want the bigger H8 in a genuine Volvo batt, ask for Part no. 30772231. This is NOT a Johnson/Interstate model, it is a German made Varta. It is also about $50 more than the standard batt.
I suspect that the HD Volvo is still coming from across the pond because the Diesels it runs are there and not here.
Interstate DOES make an exact-fit H8 equivalent for those who don't want to pay $$ for the sauerkraut-filled Volvo one.
Ask for the Volvo HD or H8, and the dealer will look at you funny and tell you all they have is the standard size. Give them the above part no and insist on it if you want one. After 5 minutes of chit-chat in the back, they'll finally put one on the counter.
But it fits fine in most P2s and will give extra capacity for those that want or need it. Just one more option.
As always, double check your particular tray first. Also be sure if you deviate size and/or brand that the vent hose will reach the new one.
Happy motoring all.
Happy motoring all.
