Just completed a Mobil 1 oil & cartridge filter change on a 2010 Model V6.
While underneath noticed the fill and drain locations for the transfer case and differential. As those locations are drained and filled in the near future, a transmission fluid drain and fill will be done.
I've located the drain for the transmission fluid on the pan but see no dip stick or location to fill. I've read of forum postings completing such task with attention only to locating the drain on the pan under the plastic shroud. I am aware of Toyota's WS fluid and it's lifetime no change view however it will be done regardless. The vehicle has 50k with the tow package and has towed cross country. It runs great at this time.
Any insight where to fill?
