Originally Posted By: vssjim
We never buy motorcraft and I have yet to see a motorcraft factory as they MAKE NOTHING. motorcraft is just a name they have low bidders make and package and then they sell at high prices. All the brake parts I have seen labeled motorcraft in the last few years are all china parts just jacked up prices for cheapy brake parts. We also 100% use Akebono Pro Act pads, great feel, good stopping, no noise, no dust, good on rotor life and good pad life also.
You may be right. Not all Motorcraft parts are good (except for engine mounts. I swear, all or most store brand ones are junk compared to them). However, fluids do have a good reputation, engine oil as well as ATF. I forgot the name of who makes the Motorcraft fluids, but they are a major refinery, the same that makes Kendal syn blend. In any case, in my experience with a Taurus, the transmission always run fine on MC Mercon V. Once I used a mix of Castrol and Valvoline Mercon V (simply used what I had), and I did not like the result. Frequent shudder and slips right after ATF change. The car is doing fine right now after I added a bottle od Lubegard Platinum. It could also simply be due to the age of car. I am still going back to Motorcraft on the next ATF change.
