I have an older Gravely riding tractor with a 50 inch deck.
I am looking for the best grease (cartridges) I can get that doesn't wash out, stays in place, lasts, and does it's job!
Even though I say lasts, I change it about twice in the summer, because I am a firm believer in it "NEVER hurts"! These spindles are not cheap, not to mention the installation!
I was actually not aware of the different greases, so I used whatever Wall Mart or Tractor supply had so I can't tell you what it actually was.
There is no "SANE" way to degrease these spindles if what is suggested is not compatible with what's in there already.
I have been told not to use a Moly grease because it builds up on the spindle bearings and causes problems.
Therefore the problem. Suggestions for an awesome grease under these conditions? Please expound to your hearts content!
