Sorry to resurrect a thread, I'm probably going to [censored] someone off so I apologize in advance.
But correct me if I'm wrong, I thought oil (ex: 5w30) was a 5 weight at normal temps and a 30 weight at higher temps to protect the engine more. Right? So, if the oil is hotter the oil is HEAVIER and thus will be slower to drain out than if it was cold --- especially if the car was sitting overnight and all the oil had time to drain out of the engine.
So wouldn't it be better to change oil when it's cold? 1. All the oil is in the pan ready to drain. 2. The oil is at it's thinnest thus you'll get more of it.
Cuz if you heat it up, it's going to be all over the engine in a 30weight (more syrup like) and not completely drain out vs if you had it sitting overnight and it drained all off the engine.
I too grew up with people telling me to drain it hot because it would drain faster. But, how?! Hotter oil = heavier thicker oil? Am I missing something?
