What can cause a clunking noise at speeds under 10 mph in the right rear suspension of a '96 Lumi Base sedan, not an APV? It has 72k on it. Fairly new Michelin tires. Original struts. How can I test for a bad bearing on the rear? Will jacking it up and spinning the wheel tell me anything? This noise is only at say 3 to 10 mph. Above that , the noise completely goes away. I am thinking either a bad tire, bad bearing hub, or a bad suspension such as strut or bushing in the right rear. For those of you with W-body GM FWD cars '88-'96, you may know about the transverse monospring isolator pad going bad on the rear of your cars. The fix is cheap-about 20.00 for new , upgraded pads and easy to replace. I found out the 95-96 Lumina was a different suspension design. If you know about these Lumina's, please let me know.
