I have a friend here at work that has a 99 Ford F-250 with the 7.3L Diesel. He has 280,000 miles on it. He's owned it since new and keeps it well maintained. The other day he was on the highway and it died. He was low on fuel, but didn't run out. He took of the valve covers and fiddled with some connector and after getting two new batteries it started. But it takes 12 cranks to get running now (used to be 2 or 3). And once it's running it runs a little rough.
He thinks he may have sucked some garbage up from low on fuel. I recommended he put in some kind of diesel cleaner and about 5 gals of diesel and run it hard for a bit to see if that cleans up the injectors.
What do you'all think?
Recommendations on what diesel fuel cleaner to use also please!
