Originally Posted By: 95busa
AK-
Reliable, hits pretty hard close in. Sights are primitive, ergonomics are atrocious, magazines and ammo are heavy. If you are a casual rifleman in combat it is an acceptable weapon. I have fired AKs extensively and like the weapons, but not my first choice.
M16 family of weapons (generally speaking to M16A2/A4/M4)
Very accurate, excellent ergonomics (quick reloads, great firing position, control manipulation, etc). 5.56 is not ideal especially out of short tubes like the M4, but it does the job- and is accurate to 500 meters+. Excellent iron sights, models after the A2 are easily adaptable to excellent optics like the ACOG, even the A2 can take a CCO. Down side- Maintenance intensive- if maintained well they function well for a long time, but at some point your are going to have to do some detailed maintenance on them. You can do a quick scrub of the bolt, carrier, chamber area and punch the bore a few times, lube em up and get them running again pretty quickly, but once again a cleaning to standard takes time and effort.
Well said. AR/M16 easily built and repaired as well. Literally a plethora of aftermarket items to add on if one wishes, and superior optics platform. AK is sure a stout weapon but most suffer in the accuracy department.
