1995 Mercury Grand Marquis 4.6L
Lab: Oil Analyzer's Inc.
Oil: Amsoil Signature Series 0w-30
Oil Filter: EAO11
Sump Capacity: 5 quarts
Oil Miles/Time: 3,784 miles/14 months
Total Miles: 132,539
No make up oil added, no filter changes.
Oil was changed.
Iron - 17
Chromium - 1
Lead - 3
Copper - 7
Tin - 1
Aluminum - 1
Nickel - 1
Silver - 0
Silicon - 29
Boron - 6
Sodium - 16
Magnesium - 20
Calcium - 3818
Barium - 0
Phosphorous - 733
Zinc - 918
Molybdenum - 3
Titanium - 1
Vanadium - 0
Potassium - 49
Viscosity 100 C - 10.0
Fuel < 1%
Water = < .1% FTIR
Nitration - 15
Oxidation - 53
TBN - 5.47
Previous analysis:
Amsoil HDD 5w-30 - http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=916411
After my last oil analysis I performed an Auto-RX clean and rinse cycle. Refilled with 1 gallon of Amsoil 0w-20 and 1 quart of Amsoil HDD 5w-30, but did not perform an analysis. Then did a Amsoil Signature Series 0w-30 oil change, but I didn't do an analysis either (regret not doing it because I went at least 8,000 miles that time).
When I changed the oil, I took the sample, then refilled with Super Tech oil, added the Amsoil Engine & Transmission Flush, and then changed the oil and filter. I let this drain for a couple of hours before refilling with Amsoil 0w-30 SSO.
I cleaned the throttle body and IAC Valve (which appears to be malfunctioning still).
They flagged the Silicon level, but several of the wear metals are lower. Potassium was flagged as well, but there is no moisture, wear metals are in good shape, viscosity is normal. Oxidation was also also flagged as moderately high.
With the increase in Sodium and Potassium, I am a little concerned, but I'll do another analysis after my next oil change.
Right now, there isn't anything major I see happening. Will trend analysis and go from there.
All comments are welcome.
Oil Filter: EAO11
Oil was changed.
Iron - 17
Chromium - 1
Lead - 3
Copper - 7
Tin - 1
Aluminum - 1
Nickel - 1
Silver - 0
Silicon - 29
Boron - 6
Sodium - 16
Magnesium - 20
Calcium - 3818
Barium - 0
Phosphorous - 733
Zinc - 918
Molybdenum - 3
Titanium - 1
Vanadium - 0
Potassium - 49
Fuel < 1%
Water = < .1% FTIR
Nitration - 15
Oxidation - 53
TBN - 5.47
Previous analysis:
