I read the post by another member where a Mobil technician told him that sulfated ash was a problem for DI engines and would be a target for reduction in GF6 specs. [I can't seem to find that thread so if someone could post a link, I'd appreciate it.]
As my DD is a Mazdaspeed3, a DI, turbo problem child when it comes to oil, I am looking for the "ultimate" solution in oil choices (preferring to stick with Mobil1 or Pennzoil) and now, here's another factor to consider. Can someone who understands these things provide a primer on sulfated ash, why it's used in motor oil to start with and why it's not a good thing for DI engines?
Perusing the Mobil1 spec sheets, I find the following SA content:
0W-30 = 0.9
5W-30 = 0.8
0W-40 = 1.3
Note that Pennzoil does not publish SA specs.
I was considering trying 0W-40 in this engine to offset fuel dilution but with 62.5% more SA, this new information makes it seem like a bad idea. 5W-30 also is the only visc with HTO-06 approval, so it looks like M1 5W-30 is the best choice although it still didn't help my fuel dilution issue which makes the oil a 20 wt by 3000 miles.
Note, as an added concern about viscosity, Mazda recently issue a bulletin extending the warranty coverage on this turbo and timing chain with a very strong warning that this extended coverage was only valid if the minimum oil viscosity of 30 wt is used.
So, for those of you in the know about add packs and the role SA plays, I'm very interested in feedback on this issue with DI engines such as mine. Thanks for playing.
0W-30 = 0.9
5W-30 = 0.8
0W-40 = 1.3
