Originally Posted By: artbuc
[censored]!! Bought these tires because the Potenza 960 AS Pole Position have been discontinued. Looked forward to getting another set of high quality tires made either in the USA or Japan. Guess what? These [censored] are made in Thailand. And, to make it worse, they are a new design. Hope I am wrong, but I am not optimistic about the quality of these tires.
As stated, the new Serenity Plus is wickedly expensive. And it's a totally different tire type from the RE series. The former is a GT design; the latter a stickier less comfortable and less-lasting UHP.
To give you an idea, the Serenity line competes with the Michelin Primacy MXV4. It is a very good all-around tire, but with an emphasis on comfort and treadlife. All the things that the RE series is not. The RE will stop, corner and track better than a Serenity.
If you don't like the Serenities and are within the trial period, you should be able to swap them out for another B-Stone tire set. And whoever at the "tech center" steered you from REs to Serenities did not know what they were talking about. These two are VERY different tires.
BTW, the new RE970 is a REALLY good tire. Way better than the 960 from the initial user reports. I have a set of 970s and can vouch that they are excellent.
I wouldn't worry too much about country of origin if it is from a major maker, even though we all have our biases (even me - I prefer US made when possible and won't buy ANY tire from China). But sometimes the size locks you into that.
